Hi all, I'm a bit out of the loop with hardware as I didn't plan to upgrade this year, but the mobo in my gaming comp is dying, a couple of the USB's have gone, along with the onboard sound on Friday and I have been getting the odd BSOD, so guess it is time for a upgrade, I would normally do lots of research started a few weeks before I planned to upgrade but this has caught me off guard and I want to order ASAP.
The spec of my current system is:
[email protected].
Asus P8P67 Pro.
Noctua NH-D14,
2x7950 in crossfire.
8Gig Kingston HyperX (1600mhz).
850watt Corsair PSU.
I play a lot of MMO's and picked up a Dell 27" earlier this year and tbh the above did struggle in MMO's in busy areas and on raids with the graphics turned up at the higher resolution, so would like a bit more CPU grunt.
I have been eyeing up a 4670k, but a bit lost on what mobo to go for my gaming comp is just used for gaming, so I don't need all the bells and whistles, just good OC options and crossfire support. Currently looking at Asus Z87-PLUS any other recommendations? have had Asus in my gaming comp for the last 5+ years but would consider others.
Also would I be as well getting new Ram and will my Noctua NH-D14 fit on a 1150 with the standard 1155 fitting kit?
Cheers
[email protected].
Asus P8P67 Pro.
Noctua NH-D14,
Cheers
