Hi guys,
A friend of mine is considering buying a new PC but his budget is limited. I am considering passing down my current PC to him at a reasonable price. This actually happened with my last PC around 4 years ago, which lasted him well since then and only cost him £100!
Anyway I need advice for my own upgrade.
Here are my current specs:
I actually have a 780GTX but I am going to keep that and replace it with my old 560TI which is still knocking about.
So, I am looking for advice in a number of areas.
Should I upgrade to Haswell?
Presumably 8GB DDR3 will still be enough, and not limit me in any way.
Any case recommendations. It needs to be big enough to hold a 780GTX.
I'd like a motherboard with space for a relatively chunky after market cooler - or perhaps just a low profile after market cooler would be better? I had a friend who bought a large AMC and it was too large for either of other motherboards - hitting the RAM.
Finally, a reasonably priced powersupply with 2x8Pin's for the graphics card would be idea. My current one only had 1x8Pin and 1x6Pin which I had to adapt using Molex connectors into an 8pin.
Thanks in advance.
- i5 2500k
- 8GB DDR3
- 560TI
- 1TB WD HDD 7200RPM
Thanks in advance.
