I postponed a possible upgrade earlier in January to see what affect the release of the non ref 290 and mantle had on the GPU market.
my current GTX570 has reached a point where it is really struggling with the recent gaming lineup (bf4, dayz etc). A previous suggestion of dusting was attempted and may have mitigated the jet engine noise somewhat but i still have that upgrade itch.
so really its out of a gtx780 or a non ref 290. id appreciate any advice.
I'm thinking a budget of between £350 & £400, the rest of my spec is below (and yes that will be upgraded at a later date
Thanks,
Thanks,
Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz (Nehalem) (Socket LGA1366)
Thermalright Ultra-120 Extreme CPU Cooler (Socket LGA1366/LGA775)
Gigabyte GA-EX58-UD5 Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
EVGA GeForce GTX 570 HD 2560MB GDDR5
Be Quiet! Dark Power Pro 650W ATX2.2 Modular SLi Compliant Power Supply
Coolermaster Storm Scout 2 Advanced Gaming Case
Samsung 840 Series Pro 256GB SSD
CORSAIR CMX12GX3M3A1600C9 12GB (3 x 4GB) (one stick failed so down to 8GB
