- 6 Jun 2011
Hi all, I've had a lot of great help from this forum over the last couple of years getting a PC assembled that has helped me enjoy gaming a lot more but I'm starting to think about upgrading the machine as newer games are arriving. I'm also thinking a SSD is possibly going to be a good purchase to make too.
I was hoping to get some advice on what people thought would be the best options on which bits to prioritise. If I remember rightly the motherboard in particular was a bit of a compromise when I first started putting it together so perhaps that will need replacing first.
Here's my current spec:
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM
Asrock Z68 PRO3 Intel Z68 (Socket 1155) DDR3 Motherboard
ATI Radeon 7950 HD 800MHz 3GB PCI-E HDMI Windforce 3X OC
Crucial Ballistix Sport 16GB (2x8GB) DDR3 PC3-12800 C9 1600MHz Dual Channel Kit
Western Digital Caviar Blue 500GB SATA 6Gb/s 16MB Cache - OEM
Antec High Current Gamer 620W Power Supply
Antec 100 One Hundred Ultimate Gaming Case
Gelid Tranquillo CPU Cooler
I haven't really thought too much about a budget but around £300-£400 would probably be the area I was looking at initially. Any advice or suggestions on where to start would be much appreciated. Thanks.
