Hi,
BitFenix Merc Beta Gaming Case
OCZ ZS Series 650W '80 Plus Bronze' Power Supply
I think there is something wrong with my card to be fair, and my friend said i should think about getting an 280X - someone else mentioned a r290 but i have purchased a 144hz monitor so only have that amount left!
thanks
The cheapest 290 on here atm is 290.![]()
I'd start at the other end - what are you finding doesn't run well enough now on your 7850?
Also, what speed is your 7850 running at, likewise your 2500k. How much RAM do you have, what OS are you using, what driver, what is it you expect this upgrade to get you, all the usual suspects!
