Hi,
I've been really happy with my system, (spec shown in signature) and it still plays everything at full detail on a single 1080p monitor and fairly well with lower settings across 3 in surround mode. A couple of months ago, I bought an Oculus DK2 and noticed that some of the apps are dropping below 75FPS which as a lot of people know, can indude motion sickness after a while. I know that some of this is down to the current resolution of the DK2, latency and where apps aren't necessarily optimised, but it made me think about whether it's time for an upgrade, especially after reading that the GTX 9 series will support VR SLI.
The problem is, having 2 x GTX 670 4GB cards makes it difficult to justify changing to one GTX 980 as there's not a massive difference in performance and I can't afford 2 x GTX 980s without leaving the rest of the system without an upgrade.
My wife said that she'd buy me part of an upgrade for Christmas, around £300-350, (I know, I'm a lucky man!
) and I could probably buy myself some bits equalling around the £400 mark, but I'm not sure which of these options to go for:
1. Upgrade the rest of the system with a high-end Z97 board, an i7-4790K, new memory,(maybe) and then keep my GTX 670s for a while until I can afford 2 x GTX 980s.
2. As above, but not upgrade the memory and use that money to stretch to buying one GTX 980 and then add an additional one when I can afford it.
3. Buy 2 x GTX 980s and replace my existing GTX 670s leaving the rest of the system as it is, (although I'm not sure whether this will be a bottleneck).
4. Wait for Skylake and associated motherboards and / or wait for NVIDIA's next generation of cards.
Any recommendations on which option to go for would be very much appreciated. I just want to make sure that if we're spending around £750-800 on an upgrade now instead of waiting, that I'll see some kind of noticeable difference.
Thanks!
) and I could probably buy myself some bits equalling around the £400 mark, but I'm not sure which of these options to go for:1. Upgrade the rest of the system with a high-end Z97 board, an i7-4790K, new memory,(maybe) and then keep my GTX 670s for a while until I can afford 2 x GTX 980s.
Thanks!
