Upgrade Advice
17 Nov 2011
Timbucktoo
Evening all,
I need some help/reassurance regarding an upgrade please.
I currently have:
i5 3570k @4.5ghz
Asus 7950 DCUII Top
8GB TeamGroup 2133GHZ Ram
75gb Intel SSD
120gb SSD
460gb HD
Corsair H100i
NZXT Hale 550W
CM Storm Stryker
So, the plan was before christmas I was going to downsize the case and change a few things. This never happened, and there is now no need to downsize.
However, the GPU is getting a little long in the tooth, and games such as Dying Light, that I would liked to have bought on the PC, I have had to buy on the PS4.
So, I was/am planning on just updating the GPU. I have been looking at the
http://www.overclockers.co.uk/showproduct.php?prodid=GX-155-GI
and obviously need to change the PSU
http://www.overclockers.co.uk/showproduct.php?prodid=CA-024-SF
I have no plans to SLI, so presume that PSU will handle what I need it to?
I only play games and surf the net. No other work/uses. I game at 1080p, although would like to/will move this to a better resolution within the next 6 months.
Cheers.
The NZXT is a good PSU and will handle the load of the 980, 600w is for those who by the cheap nasty psu.
Review of the PSU:
http://www.legitreviews.com/nzxt-hale82-v2-550w-white-psu-review_128393/8
And gpu:
http://www.guru3d.com/articles_pages/gigabyte_geforce_gtx_980_g1_gaming_review,7.html
Here is Guru3D's power supply recommendation:
GeForce GTX 970 or 980 - On your average system the card requires you to have a 500 Watt power supply unit.
GeForce GTX 970 or 980 in 2-way SLI - On your average system the cards require you to have an 800 Watt power supply unit as minimum.
