- 3 Dec 2018
Hi All,
So a while back now (5 years) i built a mostly reasonable system:
16GB DDR3 12800
Core i5 3570K
Azrock Z77 MB
GTX 660
850w PSU
A bunch of SSD's and all the other cables etc
I then upgraded to a GTX980 in mid 2016 and the system has generally done well for my gaming needs since build and lets me play on acceptable settings at 1440p
However i feel its due an upgrade as since i acquired an oculus rift the system is generally starting to creek with the additional workload.
So my question is, am i better off upgrading the core system first, maybe a i7 8700k or i5 8600k with a decent new MB and some reasonable DDR 4, then doing the GPU upgrade in 3-4 months when finance allows, or reverse and find a good gpu to update my existing box to accommodate the rift then do the core bits later?
Thanks!
16GB DDR3 12800
Core i5 3570K
Azrock Z77 MB
GTX 660
850w PSU
Thanks!
