- 27 Mar 2019
When i first built my gaming PC back in 2015 i used all budget parts, the entire PC costing me around £500 and being able to run all games on max with no problem at the time. Since then i have replaced the standard CPU Fan with a closed loop water cooler and upgraded to a bigger case to fit the cooler in.
Thinking its about time to upgrade the other parts, load times for games are massive, i'm getting constant crashes and i cant really run any game on max graphics anymore...
Having trouble choosing parts as my motherboard is an old AM3+ socket board and my CPU only supports DDR3 RAM which seems abit out dated. Worth upgrading motherboard to an AM4 socket and then changing CPU and memory or just upgrading AM3+ parts with what i can find?
Current PC parts:
Case: Corsair Graphite 760T V2 - Arctic White
Motherboard: Gigabyte GA-970A-UD3P AMD Socket AM3+
CPU: AMD (Piledriver) FX-6300 3.50GHz
CPU Cooler: Corsair Hydro H100i GTX 240mm
RAM: 8GB (2x4GB) Crucial Ballistix Sport 1600MHz CL9 D
Graphics Card: Sapphire Radeon R9 270X Dual-X Boost OC AMD
HDD: 1TB Seagate Barracuda ST1000DM003 3.5" SATA III H
PSU: 500W - EVGA 80+ White Rated Power Supply
thanks in advance.
Current PC parts:
thanks in advance.
