Hi all, I built my own system last year after not playing with this stuff for years, It was a budget build to start with but now it needs help...current specs are
Ryzen 3 2200G
MSI Pro Carbon B450
Samsung 970 EVO M.2 500gb for a boot drive
Viper Steel 32GB 3200MHz... this was an upgrade from the initial 8GB
AMD Radeon RX 580 8GB...upgrade also from using the one on the cpu
WD 2TB storage drive...also added
I primarily play Warzone with this and it's beginning to suck, with the GPUs still expensive I was going to upgrade the CPU but I wasn't sure how good and pricy I needed to go.
Any advice would be appreciated
Thanks
Ryzen 3 2200G
MSI Pro Carbon B450
Thanks
