upgrade advice.
10 Jun 2021
london
Hi,
I have decided to go for the following build
My basket at OcUK:
Total: £1,144.03 (includes delivery: £12.30)​
I would like some help with the storage options if possible and any other things that are missing and need to purchase. Haven't built a pc since 2013.Are the PSU cable extension fine or need others. Would have gone for MSI Tomahawk but not available atm.Is the PSU quiet as i couldnt find one that has hybrid mode as my current EVGA G2 one.I have already a GPU hence the reason i didn't purchase one.
Thank you.
Which GPU do you have? And that PSU is going to be woefully underpowered should you wish to buy a new GPU like a 4080 or 4090 down the line.
The 12400 is the best bang for the buck Intel CPU but you might consider stretching to the 12600 so you can take advantage of the efficiency cores. And I don't know when the 13400 and 13600 (non-k) are going to be released but it's going to be sometime soon.
Not planning to buy 4000 series ..i have a 6650xt that is enough for my needs (Diablo,League of Legends..some emulator games)
Would personally go for a black and grey or white motherboard like the Asus prime Asrock steel legend just think it will blend the build rather than harsh black motherboard.
Had a look at but out of stock.Also had a look at rog Strix B600-A.Not very fussed about color to be honest.....just for everything to be compatible.
