Firstly, thanks a ton to all the guys who helped me in my last thread, offering good sound advice which kept me with some money in my pocket. However, since then I've been having some issues with my setup which I can't pinpoint (thread here).
So that of course got me thinking again, about this upgrading malarky. With some apparently tempromental ram that only decides to fail memtest when it feels like it, its pretty hard to nail down a fix, and rather than buying new DDR2 ram at its current price, combined with the fact that one of my friends recently changed from PC10666 to PC12800 DDR3 ram, means I can pick up the 2x2gb 10666 sticks pretty cheaply, with just a couple of weeks of use on them.
Now, with all the new CPUs coming out next year, along with new chipsets for both AMD and Intel, I'm looking for futureproofing, at least as much as I can. From what I've heard, Intel's CPUs won't be backwards compatable, but with the AM3 800 chipset apparently Bulldozer support can be added through a new BIOS. And given they have the best value CPUs at the moment (Right?) its likely I'll go that way.
Originally, I was looking at the Phenom2 X6, but thinking about it, that's too much for what I need, the X4 965 should be enough, the higher clocks will be more useful for gaming then more cores. The ram is sorted, that just leaves the cooler and mobo.
Cooler first, I've currently got the Thermalright IFX14. Now... when I brought it, I don't think it was AM3 compatible (It wasn't even out), but apparently it is now. I'm guessing that it just needs a new fitting, so I may try and contact Thermalright see if I can buy/get the fitting for free, which saves a headache.
Which leaves the one thing I'm really not sure about, the motherboard. I've had a good look at the 800 chipset ones, and after getting rid of the microATX ones, there doesn't seem to be much difference at all between them. Sata 3/6gb, usb2/3, but that's it really. The cheaper ones will probably be worse overclockers, but at what price point does it become 'good enough'? Especially looking at the £40 price jump from the £120 to £160 boards. I could afford one of the £160 boards, but I don't really want to spend that much unless it would deffinately be worth it. I guess it would make Crossfire an option in the future with my 5770, but ideally I would sell that and buy one of the SI cards, as they'll be more powerful, and single card solutions are going to be more efficient.
Only requirements from the mobo are 5 sata ports for my hard drives, and 2 PCI slots for my wireless and sound cards. Plus good overclocking ability, naturally.
So, my current spec would be:
Just needs the perfect mobo to go with it. Though as I said, ram and cooler will be dealt with seperately, just got them there for reference
