Upgrade an X1800XT with £100 max budget
11 Jan 2006
Basically i'm looking to upgrade my X1800XT to something a little newer with more punch but i've only got £100 max to spend is it possible to get a better card for that money or should i say is it worth it? & would i be better going for ATI or Nvidia ?
I play COD4 online & would like to play with everything maxed'ish if possible
How would that perform Against my 1800XT ?
And also which would be better the 8800GT or the 9800Gt
The 8800 GT would totally destroy the x1800 XT, its way, way faster, i went from an x1800 XT 512mb to an old 8800 GTS 320mb, and even that was more than double it, then i went to the GT from that which totally annihilated it, the performance increase will be bloody mahoosive, adn that price of £105.74 is ******* amazing. :D
The 8800 GT is also better than the 9600 GT. :)
Thats the 9600 GT, which is slower than the 8800 GT, it came in as the old 8600 GTS replacement (which it destroys), and also came in below the 8800 GT, as it has less stream processors, its still a stonking card as well though, and not really that much slower than the 8800 GT in certain games. :)
Good review of the 9600 GT here :- http://www.firingsquad.com/hardware/nvidia_geforce_9600_gt_performance/
Id still get the 8800 GT though, as its only a fiver more.
Ahh it's all in the detail :p
Cheers the the help guys i think i'll try my luck with the 8800 :D
would a 8800GT last me another 18 months over my now dead 1900xt?
when do the this week only deals run till?
VeNT the 8800GT's lifespan will depend on what you do with it.
if you want to play graphically demanding games on a 30" monitors native res with a very high FPS or if you decide to kill it by ocing it to a stupid speed then it wont really last 18 months but if you are willing to accept that depending on what res you game at, the card may be less able to cope with games in the future as the minimum spec needed for good framerates increase and you are able to cope with a possible drop in res ,FPS or picture quality then i think it can last 18+ months.
oh, one question, what drivers are best for this card? any 3rd party ones (omega?) or just standard?
