Hi all,
I built my system, after advice on here, about a year and half ago now.
Specs:
Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W)
Asus Z77 Maximus V Gene Intel Z77 (Socket 1155) DDR3 Motherboard
CM Storm Stryker Full Tower Gaming Case - White £116.66
XSPC RayStorm 750 RS240 WaterCooling Kit V4
TeamGroup Xtreem LV 8GB (2x4GB) DDR3 PC3-17000C11 2133MHz
Asus 7950 DCUII Top
Patriot Torqx 128gb SSD
Intel SSD 75gb (don't know the model number on this -sorry)
Basically, I need to kind of downsize. The PC has to be moved and I need to make everything 'smaller', the case takes up a fair bit of room. Also the case has twice had beer spilt on it and the front USB ports are no longer working.
I was looking at a Parvum Systems case. I think my mobo will be okay to go in that? So can obviously keep my processor as well. However I take it my GPU and watercooling system wouldn't fit in this case? But, that needs to be the kind of size case I am after - so suggestions and specs please?
I don't mind throwing about £500 at it, and I can make a bit of money back by selling some of my existing components, so could go a little over that 'budget' if necessary.
I don't suppose they can be discussed here, but something along the lines of the upcoming Steambox size would be ideal.
Thanks.
Specs:
Asus 7950 DCUII Top
Thanks.
