- 7 Apr 2009
- Blighty
Hi all
Finally putting together a major upgrade from my current (prehistoric) build. Hoping for any recommendations and compatibility info that might come to mind.
Planning to use my existing GPU for now (a lil' 650ti) and existing power supply (non-modular BeQuiet 500W). But might consider adding a new PSU to this if anyone recommends a good modular & v. quiet model.
Will be used for general stuff, movies, Photoshop, gaming/modding. Want it as stable, cool and quiet as I can get it. No plans to overclock this build.
Case: Silverstone Tj08-E http://www.overclockers.co.uk/showproduct.php?prodid=CA-077-SV
Board: Asus H97M-E http://www.overclockers.co.uk/showproduct.php?prodid=MB-620-AS
CPU: Intel i5-4460 http://www.overclockers.co.uk/showproduct.php?prodid=CP-535-IN
Cooler: ???
Memory: Elite Black 16GB http://www.overclockers.co.uk/showproduct.php?prodid=MY-034-TG (or 8GB?)
Drive 1: Crucial MX100 128GB http://www.overclockers.co.uk/showproduct.php?prodid=HD-035-CR
Drive 2: Crucial MX100 256GB http://www.overclockers.co.uk/showproduct.php?prodid=HD-036-CR
For the CPU cooler, I'm looking at the BeQuiet Shadow Rock Slim (http://www.overclockers.co.uk/showproduct.php?prodid=HS-009-BQ), but unsure if that's a good fit for this build & the TJ08-E?
Slightly worried about some negative reports about the TJ08's build quality and noise levels, but many others say it's a great case? I also looked at the Aerocool Dead Silence and similar micro-ATX cases...
Thanks in advance for any suggestions/reassurances.
Cooler: ???
