- 10 Dec 2012
First I would like to say that seven years ago I got a build here that lasted myself this long, other than upgrading to a gtx 1060 6gb a year and a half ago when I got into vr my build lasted that long and ran everything fine, so its time to upgrade.
With how old my last build was there is no point in comparing them lol so I will just post my basket to see if anyone spots any issues:
My basket at Overclockers UK:
So first thing I am going to transferring my gtx 1060 6gb as it has done well and I am going to wait a bit till say a rtx 1080s get cheaper in price maybe in a year or two, its the only thing I am bringing over as everything is staying in my old system as I am going to be re-purposing it.
My budget was around 1k but I added an extra 200 to it as I wanted to upgrade my monitor as well.
Starting with the cpu I picked the AMD Ryzen 7 3800x as it looked to be the best of the current AMD Ryzen 7 cpus other than going past into Ryzen 9 and thread ripper territory which the cpu alone would cost half to the total build cost, from what I have read looking at other upgrade builds it looks like currently AMD ryzen 7 gets most performance for cost at the moment.
Next is the motherboard I went with the AMD AM4 3rd gen boards as I wanted to make sure all features where future proof at last, the first shown one was the Gigabyte x570 as it basically had everything I wanted and my current board was made by gigabyte I picked it. Although in seven years who knows if they kept up the reliability.
Memory next, one regret I had last build was not going for more memory at the time 8gb sounded like a lot but over time it became standard and now is one of the factors holding everything back, with the design of my board and heat sink i can not add more memory as well. So this time I picked 32gb at 3200 and a CPU cooler that had cuts to its fins to stop memory blocking.
I got a CPU cooler in the performance range that also had cuts in the fins to stop blocking the memory slots hope it works.
I went with a nice airflow tower that looks a lot like my old case, I am not that into RGB I would rather have it sit nice quite and cool than look good.
I added two SSDs a kingson A480 for the OS and a Samsung 1TB for my steam drive, the case can hold up to 10 drives I have lots of room to expand storage space which I feel I will do.
Now on to power supply as someone who had a tower die from a cheap power supply which lead to my last build I picked a Kolink 80 plus gold modular power supply any issues with this one? I used part picker to figure out the wattage and it came to 354w so 500w should be plenty including future GPU upgrades.
Lastly I am upgrading my monitor, its the same size as my old one but its gone from 60hz to 144hz It looks like it has good reviews.
So there hopely is my next build for at least the next 5 years which is the time limit I give myself between upgrades, upgrading to a 1060 6gb added the extra years to my old tower so hoping to do the same in a few years with this one.
Any help on issues with parts anything i am missing would be great as the advice here last time helped a lot.
Thanks
Jason
- 1 x AMD Ryzen 7 3800X Eight Core 4.5GHz (Socket AM4) Processor - Retail= £299.99
- 1 x Gigabyte X570 GAMING X (AMD AM4) DDR4 X570 Chipset ATX Motherboard= £149.99
- 1 x Patriot Viper Steel 32GB (2x16GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit (PVS432G320C6K)= £149.99
- 1 x be quiet! Dark Rock Pro 4 CPU Cooler= £73.99
- 1 x Corsair Obsidian 750D Airflow Full Tower Case - Black (CC-9011078-WW)= £142.99
- 1 x Kingston A400 480GB SATA 6Gb/s 2.5" Solid State Hard Drive - (SA400S37/480G)= £59.99
- 1 x Samsung 1TB 860 QVO SSD 2.5" SATA 6Gbps 64 Layer 3D V-NAND Solid State Drive (MZ-76Q1T0BW)= £109.99
- 1 x Kolink Enclave 500W 80 Plus Gold Modular Power Supply= £59.99
- 1 x LG 24GL600F-B 24" 1920x1080 TN 144Hz 1ms FreeSync Widescreen LED Gaming Monitor= £139.99
Thanks
Jason
