I've got the following setup, and the display has gone wibble- most likely candidate being the graphics card. I was planning on upgrading soon anyway so I'm trying to decide whether to buy a cheap second hand card or spend £100 and get a new card. If I get a new card, will it be compatible with my existing setup? If so, which one shall I get?
AMD Athlon X2 4200
4GB DDR2 RAM
GeForce 8600 GTS (pci-e)
XP Pro
Help appreciated.
AMD Athlon X2 4200
4GB DDR2 RAM
XP Pro
Help appreciated.
). Possibly the cards mentioned above if you have the PSU for them.
