- 22 Jan 2010
Now I bought my system pre built almost 2 years ago, not really knowing very much about computer hardware.
Mobo: ASrock 4CORE1600P35-WIFI
CPU: Intel Q9450 2.66ghz
Graphics card: 9800 gtx
RAM: Corsair value select 667mhz (8GB)
I play a lot of games but also use programs like 3ds max, zbrush and photoshop; mainly for creating game assests. It performs fine for the latter tasks but it's starting to struggle playing newer games.
Now I think upgrading my card is a given, probably to an Asus 5850 if they ever come back into stock. What I need help with is my cpu really.
So my CPU is struggling, espiecally with games that don't use the multiple cores. I know it would fly if I was able to overclock it properly. Problem is I can't get it much higher than 2.8ghz or my system freezes and a horrible noise comes out of the speakers. Seems to me that the RAM is the obvious culprit (although I'm sure I haven't got all that great an ocing board aswell). Being only 667mhz means I can't set the divider lower.
So this leaves me with a problem aswell as various soloutions
Soloution 1 - Buy faster DDR2
Could replace all of my ram with faster DDR2
Pros: should be able to overclock my current cpu to decent levels
Cons: ddr2 prices are really high right now and don't feel like value for money
Soloution 2 - Buy DDR3
My board supports DDR3 1333
Pros: Would be able to overclock even higher and would probably be cheaper
Cons: My board only supports up to 4gb so would lose 4gb of ram
Soloution 3 - Buy new mobo that supports more DDR3
Could buy a new mother board that would allow replace all 8gb of my ram for ddr3
Pros: lots of fast memory
Cons: More expensive and would have tp replace when I upgrade my cpu.
Soloution 4 - Buy new mobo cpu and ram
I could just rip out the whole lot and upgrade it all.
Pros: New fast CPU that I can OC really well. Wont need to upgrade again for a while and when I do I can probably keep the RAM and possibly even the mobo.
Cons: Expensive
I get a student loan payment on the 19th so I will use that. I think my max budget would have to be £500 including a graphics card but of course the lower the better
Please can I have your thoughts and product recomendations.
Thanks.
PS if i did go for soloution 4, how much do you think I could get for my old parts? (my 9800gtx has one if these if it makes any difference)
Cons: Expensive
Thanks.
