Hi all,
Yesterday I bought a new system with the case being a Thermaltake S100 Micro-ATX case which only comes with a single 120mm rear exhaust fan, but apparently can accommodate two 140mm or three 120mm fans at the front and a 280mm radiator on top (so I assume two 140mm fans?).
Although I haven't yet built the system (I'm presuming it will arrive Tuesday) I'm already thinking about adding some extra fans to the case as a single exhaust fan doesn't sound a lot and I don't want any chance of things getting too hot.
For reference, my new build is below:
AMD Ryzen 5 3600 Six Core 4.2GHz (Socket AM4) Processor - Retail
Arctic Freezer 34 CPU Cooler - 120mm
MSI MAG B550M Mortar WiFi (AMD AM4) B550 Micro-ATX Motherboard
Gigabyte GeForce GTX 1660 SUPER OC 6144MB GDDR6 PCI-Express Graphics Card
Team Group Vulcan Z T-Force 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Grey
WD Blue SN550 1TB NVME M.2 2280 PCIe Gen3 Solid State Drive (WDS100T2B0C)
Phanteks AMP 550W 80 Plus Gold Modular Power Supply
Can anyone recommend some options that would work with the above build (not sure if I'm limited at all with the above mobo or PSU or if I'd need to buy anything extra), I'm looking for the best bang for buck, I'm not bothered by any aesthetics or noise levels (unless it's really insane).
Any suggestions would be appreciated, thanks in advance.
