Upgrade decision
10 Aug 2011
Evening,
I've been asking a few questions over the past couple of days and I've half decided on what I'm going to spend money on to upgrade my current system.
Based on a £500 budget for upgrade which of the options below would be the best (or suggest another). This has to include a monitor.
Current Spec:
OS: Windows 7 64bit
Case: Cool Master Lite
Motherboard: M4A77TD
PSU: 500W
RAM: DDR3 8Gb (4 x 2Gb)
CPU: AMD Phenom II X4 925 2.8Ghz
GPU: PNY GTX460 1Gb
Boot HDD: 500Gb Seagate
Store/Games HDD: 1TB WD Green
1st option. Get new mobo and go SLI GTX460
LG W2363D 23" TRUE 120Hz 3D Widescreen LCD Monitor - Black
£167.99
MSI GeForce GTX 460 Cyclone 1024MB GDDR5 PCI-Express Graphics Card £117.59
MSI 990FXA-GD65 AMD 990 FX (AMD AM3/AM3+) DDR3 Motherboard £115.99
Antec TruePower New Modular 750W '80 Plus Bronze' Power Supply £85.99 (£71.66) £85.99 (£71.66)
Total About £500
2nd option
£167.99
MSI GeForce GTX 570 OC Twin FrozR III Power Edition 1280MB GDDR5 £254.99
Total £509
So SLI or not. I see that the GTX460 in SLI will give slightly better performance than the 570 alone but think i might be missing something.
The LG monitor isnt a definate but it seems good for the price. I'm not set on a 3d monitor but the 120hz is appealing as i play fps. It will mainly be used for gaming so the viewing angle is a non issue.
Any other suggestions are welcome. Everyone has be extremely helpful.
Cheers
Ben
