Ok guys so i've got ~£200 to spend on an upgrade
I currently run the following spec:
- DFI Lanparty NF4 - SLI-D
- S939 Venice 3000+ - running at 2.6ghz
- 1Gb (4 x 256mb) BH5 DDR
- ATI 1800XL 256mb - clocked to near 1800XT speeds
- Jeantech Arctic 600w PSU
- Dell 2405fpw (important as I'd like to play games at 1920x1200)
rather than ask what should i buy I've narrowed my options to 3 bundles (at least i think i have) - therefore I'd like to know which of the three following upgrades you think i'd see the greatest performance increase out of in games:
Option 1:
Connect3D ATI Radeon X1950 Pro 256MB GDDR3 HDTV/Dual DVI (PCI-Express) - £108.09
AMD Athlon 64 X2 Dual Core 3800+ (Socket 939) - £93.99
Total inc P&P: £211
Option 2:
Intel Core 2 DUO E4300 "LGA775 Allendale" 1.80GHz (800FSB) - £112.79
ASRock 4CoreDual-VSTA PT880 Ultra Socket 775 SATA 8 channel audio ATX - ~£40
Corsair 1GB DDR2 XMS2-5400C4 TwinX (2x512MB) - £51.69 (required as asrock board only 2 ddr & 2 ddr2 slots & my DDR is 4x256mb)
Total inc P&P: ~£215
Option 3:
OcUK GeForce 8800 GTS 320MB GDDR3 HDTV/Dual DVI (PCI-Express) - £192.69
thanks for looking
any advice is much appreciated
Option 1:
Total inc P&P: £211
Option 2:
Option 3:
thanks for looking
