Hi All, first post pse be gentle. I run my pc from a media centre case connected to a 1080p 37" panel. I normally only watch 720p stuff and play games in lower res's.
I have at the moment an FX55, 2GB Ram, ATI x1950gt, few hds. Its all in a Thermaltake Bach Media Lab VB8001BNS Case.
Now I need to start thinking about upgrading. I tend to play older games, BFV, BF42, Q3 etc as I'm an oldie
, but would like to be able to play GTA4 PC with my son etc.
Ideally my budget will be around about £400, under if poss. I'm reading conflicting advice on wether or not a Quad Core is needed, though looking at the feedback on GTA4 it seems it is.
So basically I need some peeps to quote me happy. I need :
CPU
MOBO
Gfx Card
PSU
Ram
Poss Soundcard ( I have an old Audigy, will newer xifi give me dolby digital over my 5.1 system using optical?)
500gb+ HD
It'll prob be after xmas before I take into the upgrade though.
, but would like to be able to play GTA4 PC with my son etc. Ideally my budget will be around about £400, under if poss. I'm reading conflicting advice on wether or not a Quad Core is needed, though looking at the feedback on GTA4 it seems it is.
CPU
MOBO
Gfx Card
PSU
Ram
500gb+ HD
