Hi all,
I need some advice. I am coming to the 2 yr mark on my computer and would normally do an upgrade to see me through another year. But I dont think there is much available for me that will make much of a difference, so I am thinking of a whole new system. I mainly use my machine for internet, gaming and video encoding. I like quiet computers and hate slow and sluggish response. I find the HD is the main culprit for this and have had problems with RAID before so not sure if I want to go down that route again.
My current system is the Shuttle SN26P which is socket 939 (hence no real upgrade path for processor). I have an AMD X2 3800 clocked at 2.5 mhz, 1 gig ram, 7800GT graphics card, a 74gb raptor for windows XP and 160 gb WD for everything else. I got the shuttle as it was compact and quiet, but to be honest its not that silent which is more important than size to me.
So I think I am pretty stuffed down the upgrade path and need a new platform. I would have about £1000 max to spend on the system. Only need the case and components as I do not need a monitor etc.
I was thinking of getting myself a cheaper P35 / DDR2 / Core 2 Duo Dual Core system which I could upgrade in a couple of years. However, I have now seen the X38 / DDR3 / Core 2 Quad systems (even Penryn). I am drawn between the 2 as the second option quite a bit more expensive but faster and a little more future proof with the DDR3 option and good overclockability. However with option 2 maybe I should wait for Penryn in which case I probably cant build it all for x-mas which is my main aim.
As far a cases go I am thinking of the Antec P182. Are these that quiet and will it be more silent than my shuttle? PSU will probably be the Corsair 620 watt PSU. Will probably go for the 8800 GT for graphics and 2 or 4 meg of ram. HDs are to be decided as I have no idea what is good, quiet, and fast at the moment.
Finally, is it worth the jump to Vista 64 while I am doing all this or will XP be fine?
Help!!!!
Sorry for the long post but any advice would be much appreciated.
Thanks in advance.
Help!!!!
Thanks in advance.
