- 24 Feb 2007
current spec is:
lian-li PC7 Plus
e6600
2gb OCZ PC6400
8800GTX
2x 7200.10 baracuda 320gb drives
1x 500gb caviar drive
1x 250gb WD drive
media card reader + floppy disk
sony DVDRW
tuniq120 cooler
stock 2x 120mm fans
Ive got a side window and it looks pretty dark so im looking to improve on that, also looking to improve on chassis vibrations being removed i.e quieter. Doesnt have to be a silent system since i use headphones most of the time but when i take them off or try to sleep i dont want constant irritation. Im thinking of buying the following:
2x Zalman ZM-2HC2 Silent Hard Disk Heatpipe Cooler (for the baracudas)
4x Akasa Serial ATA 45cm DAYGLO Orange Data Cable
1x Acousti Ultra-Soft Arrowhead Fan Mounts - 8 Pack
1x Metal Thumbscrews 6 pack - Aluminium Cases (Type 2)
1x Akasa AK-PAX-2 PaxMate Plus Acoustic Absorption Mat
1x SpeedLink Medusa SL-8793 5.1 ProGamer Edition
Can i get opinions on these parts? specifically i want to know if the hard drive enclosures will improve noise, make no difference, or make it worse cause the last 1s i got from ****** sucked (2 long stripes of rubber that the HDD screwed onto.
Also want to know if those fans have LEDs or UV etc, if not would like some LED fans which are 120mm, silent, but good airflow if any exist (couldnt really see any on OC apart from this).
Dont know if this acoustic mat thing is worth buying or not, or how it works. Any experience stories of it would be good. Feel free to comment on remaining components as well and whether you'd change anything.
The noise from my system is whats bugging me the most atm, it seems to eminate from the top of the chassis even though its just the dvdrw drive there, i think its a weak spot in the chassis design or something
lian-li PC7 Plus
e6600
2gb OCZ PC6400
8800GTX
1x 250gb WD drive
sony DVDRW
tuniq120 cooler
stock 2x 120mm fans
