- 14 Apr 2014
- East Sussex
Hi
Hoping for some help regarding a upgrade I'm now forced to do - after putting it off for 2 years. I'm a heavy user of VM's for development work I'm doing, improving capacity for this is my main priority. I also do some gaming (BF4, Battlefront, The Division, KSP).
I'm currently memory & cpu limited for VM's, and cpu limited for games (surprisingly) and some dev work. I've done upgrades over the last year to add SSD's and a decent GFX card, so don't need to buy anything like that at the moment.
I need to get to a minimum of:
32GB of RAM
4 Cores
1 PCIE x16
Ideally I'd like to have to possibility to upgrade to 64 or 128 GB of RAM in the future
I'd also prefer a higher threadcount than just a plain 4 core, but this isn't essential, i'd also like a full bandwidth PCIEx16 slot spare if possible, but again, not essential.
Current Spec:
Intel i5-750 2.67 GHz (Lynfield 1156)
8 GB (Corsair XMS3 4x2GB TwinX 1333Mhz Cas 9)
Asus P7P55D Pro (P55)
Asus GTX 970 (4 GB)
Antec High Current Gamer 620W '80 Plus Bronze' Power Supply
Samsung 250GB 850 EVO SSD 2.5" SATA 6Gbps
Corsair Graphite Series 230T Case
(Etc: + 1 x Samsung 128 SSD + 2 x WD 2 TB + Blueray Drive + 4K 26" Screen)
Budget 1K - but don't want to spend unless its needed. I will reuse current disks, graphics card, case, psu (if poss). I'm a little concerned about single thread performance on the Xeon option below, as raw MHz is lower than my current CPU,
These are the options I've come up with:
1. Cheap - but powerful enough? Not sure about AMD these days - but 4Ghz Stock is a long way above my current CPU.
AMD Piledriver FX-8 Eight Core 8350 Black Edition 4.00GHz (Socket AM3+) £139.99
2 X Kingston HyperX Beast 16GB (2x8GB) PC3-19200C11 2400MHz Dual Channel Kit (HX324C11T3K2/16)£159.98
ASRock 990FX Extreme3 AMD 990FX (Socket AM3+) DDR3 ATX £85.99
Total £385.96
2. Really Cheap - but is the CPU going to be any good? Will be better than my i5-750, but good enough for my current needs? This would give me more cores and much greater clock speed, plus double the RAM of current PC. Another £80 would give me my 32GB of RAM to,
AMD Piledriver FX-6 Six Core 6300 Black Edition 3.50GHz (Socket AM3+) £89.99
Kingston HyperX Beast 16GB (2x8GB) PC3-19200C11 2400MHz Dual Channel Kit (HX324C11T3K2/16) £79.99
Asus M5A97 LE R2.0 AMD 970 (Socket AM3+) DDR3 Motherboard £59.99
Total £229.97
3. Proper Job
Intel Xeon E5-2620 v3 2.4GHz 6-Core with Hyperthreading (Socket 2011-3) - Retail £391.49
Corsair Vengeance LPX 64GB (4x16GB) DDR4 PC4-19200C14 2400MHz Dual/Quad Channel Kit £269.99
Asus X99-A II Intel X99 (Socket 2011) DDR4 ATX Motherboard £239.99
Total £901.47
4. Do what everyone else does and just get another i5! Maybe double the RAM though...
Intel Core i5-6600K 3.9GHz (Skylake) Socket LGA1151 Processor £205.99
Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-24000C15 3000MHz Dual Channel Kit £74.99
Asus Z170M-Plus Intel Z170 (Socket 1151) DDR4 Micro ATX £102.95
Total £383.93
Help! I need a lot of power, but don't want to spend where not really needed. I don't want to do this again for about 2 years if I can help it, which is why I'm not immediately hitting buy on option 2!
Thanks for any help.
32GB of RAM
4 Cores
1 PCIE x16
Current Spec:
Asus GTX 970 (4 GB)
Total £385.96
Total £229.97
3. Proper Job
Total £901.47
Total £383.93
