- 23 Aug 2020
I have a low end PC and recently bought Flight Simulator. As expected it doesn't run great. It's playable on low settings but the scenery etc is dreadful and the GPU is running at close to 100% most of the time, CPU around 80%. I have very limited knowledge so excuse me if any of these terms/names are wrong, but this is what I understand I have:
Vig800s Motherboard
2 x 4gb RAM DDR3 (Fury HyperX)
Geforce GTX 960 (not sure if 2gb/4gb)
i5 4670K @ 3.4GHz
250gb SSD (on which I managed to squeeze MSFS)
500gb and 1tb HDD's
In terms of cooling I couldn't tell you. It has a few fans, and some big radiator type thing over the CPU that says Cooler Master on it
I am on a budget so I don't expect to achieve the spectacular images you see on trailers and youtube but I'd like to be able to run on medium/high settings so it is fairly pleasant to look at! I'm also not bothered about mental FPS numbers. As long as it's smooth motion to the eye then I'm happy.
I was hoping to keep below £300 - 400. I had scoped out a 1660 Ti GPU for £200 and then maybe find a second hand i7 CPU for £100ish. And also get another 8gb of RAM. Maybe I can do some kind of overclocking?
Like I said I am no expert, that's why I'm here looking for advice!
Vig800s Motherboard
i5 4670K @ 3.4GHz
500gb and 1tb HDD's
