Upgrade for my Nikon D90
30 Aug 2008
Hi need advice on my upgrade camera and lens choice,
I was looking at a D7200 reason is I have about 4 dx lens, 50mm, 70-300,
11-16mm, at a 90mm macro.
The lens I wanted to get for my new camera, is a Nikon 18mm-300mm f3.5
Would this be a good option for both.
Regards
John
What makes you want the 18-300? You pretty much have the range covered already unless you're selling others so you have an all in one zoom?
The d7200 is a good camera and definitely worth upgrading too
...As a Camera upgrade It's something I was wondering too. As the D90 has a front and rear dial I would be looking to keep both. I think the D750 has two but I'm not sure if any of the lesser models have more than the one.
The D7200 also has two dials, but the D5x00 and D3x00 don't.
From the D90, your only real choices are the D7200 or the D7100.
