Hi - just after a bit of advice on options for memory upgrades.
Current system is an I5 6600k, GTX 1070, 16gb DDR4 Team Group Dark Pro 3000mhz PC4-24000C15 ram, Gigabyte Z170-XP SLI motherboard.
MS Flight can be a bit choppy even on lower settings - dips into single digit frames - would a RAM upgrade help? Or is my CPU and GPU the weak link here?
If RAM would help - is there a 16gb kit I can just slot in alongside my existing RAM, or would I be best off just buying a new 32gb kit?
If at all possible - it would be great if having to buy a complete new kit to get a set that would be compatible with a newer motherboard for an eventual new system, but aware that I will be limited by my current mobo (is there any RAM that would work on my mobo, that will run at a lower speed for now, but would be suitable for a Ryzen upgrade in next 12-18 months?).
Thanks for any help.
