Upgrade from 3060Ti
27 Dec 2002
Worcestershire
I think my 3060Ti is starting to die. I am getting reboots on my machine occasionally and every time I try to launch Diablo 4 it is just resetting (no DMP file to be able to trace what is causing it) I have just purchased a new PSU (Phanteks AMP GH1000) that I will probably install over the weekend but I think I will need to upgrade the GPU as well. I have been looking at the RX9070 XT which I believe is a good upgrade from my current GPU and should future proof me for a while. I believe Sapphire are a good make and I am looking at the Nitro+. Any recommendations on if this is a worthy upgrade or should I look at something else?
Cheers all and Merry Christmas!
OCUK have the XFX at £555 and Prime at £565, whereas the Nitro is £629. I don't think I'd want to pay the extra, especially since the Nitro has the dubious 16 pin.
OCUK also have the Reaper 9070 at £480 which is still around twice the speed compared to the 3060 Ti and uses a decent chunk less power than the XT.
I have a 5950X and 64GB (4*16GB TeamGroup) @ 1867. Currently running on a 32" display 2560*1440 but I am looking to increase to something like a 37" or higher. I want to ensure I am future-proofing myself but don't want to go over the top so if the XFX or Prime would be better I am open to those options. I suppose the other option is to look at the 7900 XTX cards but as they are an older generation I am thinking to probably not go with these.
Thanks
If you're planning to stay at 1440p with that CPU, I'd be strongly inclined toward the 9070 non-XT @ £480.
Reason being, under £500 is a more attractive price for a higher-end card, the 5950X will hold the card back a little (in some scenarios, depends on the game) and it still has plenty of grunt for 1440p, along with support for newer features like FSR4.
That said, if you're going to up the resolution to 4K, then the CPU will hold the card back less and there's a bigger need for the extra frames (even though the 9070 XT isn't that much faster, around ~10%).
Personally, i find it hard to consider any of these cards future proof, which is one of the reasons I don't want to pay much.
The 9070/9070 XT do have much improved ray tracing and upscaling over prior RDNA cards, which is as "future proof" as you can get right now. But, in the longer-term, I'm not sure where graphics are going to go.
If we move into heavier ray tracing at some point, then every card out now (apart from maybe the 5090) is going to be unplayable at high resolutions in the latest games. The same goes for upscaling and AI, where will it end? it is already looking like previous gen AMD cards are getting shafted there (either due to lack of the hardware, lack of driver/software support, or both) and if this tech gets much more sophisticated it could see a larger potion of the die space allocated to it and new extensions.
I’ve been running said dubious 16 pin for about 2-3 months now, it’s fine. Inspected it the other day. Smells good lol.
