Upgrade from 4790K setup
23 Dec 2009
RG8 9
Get rid of that mobo and pay £20 more for the x570 tomahawk. It's far superior. If you don't need wifi and are happy with 1 pciegen4 nvme slot, and will be gen 3, then drop to the b550 tomahawk. If wifi then search for the b550 gaming edge(completely different to the x570 version....its a newer tomahawk with wifi6 and runs slightly cooler as slightly diff heatsink over vrm's)..it was on offer for 139 here, have seen it for 140 and readily available at 159, but not on ocuk unfortunately.
The ram is 3600c18 and is expensive for what it is. I've seen 32gb(2x16) pro vengeance rgb for £140. Look at the crucial 3600c16 instead for £79, though again you can get the rgb version at that price
That's a great gaming cpu. Some say going to the 5800x with the extra 2 core may help with longevity, but for majority of games at xmp, think its class
Thanks for the advice, so this would be better for roughly the same?
My basket at Overclockers UK:
Total: £521.47 (includes shipping: £10.50)
Or even swap out to - https://www.overclockers.co.uk/msi-mag-b550-tomahawk-amd-am4-b550-atx-motherboard-mb-359-ms.html?
I've no need for built in WiFi.​
X570 toma has a 14 phase vrm, b550 toma has a 13 phase vrm. X570 has wifi 6, b550 version no wifi, you want the b550 gaming edge wifi if you want that(which you said you don't need). Also, x570 you'll be able to run 2 gen 4 nvme drives, b550 1 gen 4 and 1 gen 3. Apart from that they are very similar, so weigh up whether the £40 is worth it. The VRM's on the B550 board are more than enough to run a 5950X cpu, so you wont be limiting yourself for future upgrades there.
I bought a b550 board, running with 3080/5800x and gen4 nvme, but then at the time the x570 was £220, so there was much bigger price gap.
either of those boards are solid choices. I've seen a 5800x advertised for £300 now, so could get the b550 board and 8 core cpu if you don't mind shopping multiple locations
6 months on busy with other stuff and looking again. Would the above still be a good choice today? CPU is now cheaper and I can get the Mobo as B grade so quite bit cheaper.
My basket at OcUK:
Total: £414.98 (includes delivery: £0.00)​
My basket at OcUK:
That's solid. To beat that you'd have to go to the new Intel alderlake CPU's, and then at £200 you'd be looking at a 12400 coupled with a b660 board, which would give you similar features to the x570 board. Only way youd improve would be something like a 12600k paired with a z690 board but price would jump. Upside is 12600k has integrated graphics which can help if you're without a dedicated gpu, and also it competes with a 5800x for performance. Z690 boards have gen 5 gpu slot and generally can take 3/4 nvme, so a bit more future proof.
I will have a look in the morning, but just looking as is, it's a good combo at a decent price..just checked ram..rgb version same price, so if you like the lights, might as well go for it. Alternative would be going for some slightly slower 3200c16, which can be had for £50/£55 ish, but the crucial is great(and micron not making anymore so once it's gone its gone)
My basket at OcUK:
Total: £83.69 (includes delivery: £8.70)
Just taking the mobo and cpu, the 5600X and b grade x570 Tomahawk is £340
Options you could do.
Below is a more affordable Z690 board, but it does well in reviews and comes with the pcie5 gpu slot, and 4 nvme slots..3 x gen4, 1 x gen3. You could couple that with a 12400F which you can get for £163 for a total of £363(so £23 more). Benefit is the mobo is more future proof, and you'll be able to drop a more powerful cpu in at a later date. It'll support gen13 intel chips that come out next year also. The mobo is new, unopened and not b grade also.
You could get the 12400 cpu which has integrated graphics also for £189 as another option, or the 12600 for £215. From one yt I've seen in gaming, the 12600 isn't that far behind the 12600k, but it lacks the 4 e cores.
Another option is to drop to a B660 motherboard as a more budget option. For budget, looking at hardware unboxed, I'd only recommend the MSI B660M-A Wifi DDR4 board which you can get for £145, coupled with the 12400F for £308.
The 12400F,12400,12500,12600 cpy's aren't available from OCuk for some reason, they just don't stock them. Neither is the MSI B660 mobo above. They have a more premium b660 Tomahawk, but think close enough where going to Z690 chipset then becomes better
From my viewing, the 12400F isn't quite as good as the 5600X, but it is slightly cheaper with B660 mobo if cost is a priority. One thing to remember though is the X570 Tomahawk isn't a budget board, whereas the B660 is a good board, but still budget, and the z690 board more budget, but still a great board (they do a Z690 tomahawk also but that's £250)
My basket at OcUK:
Total: £210.49 (includes delivery: £10.50)​
Remember with below they recommended the 12400F due to cost difference, but now with 5600X price reduction, not so simple...it you go to conclusion, it shows charts of performance of the cpu's including the 5600X
Again go to conclusion for quick view, showing the MSI board best budget B660 board
Thanks so much, you have been a great help. :)
I'm still veering towards the AMD setup. I've got a 5700 GPU already.
My one concern, which I think is ok is that I only have a 650w PSU (Superflower Leadex) but then if it can handle my current setup, it should be ok.
For reference my current setup is -
Intel Core i7 4790K @ 4.00GHz
16.0GB Dual-Channel DDR3 @ 1199MHz
Gigabyte Technology Co. Ltd. Z97X-Gaming 7
8176MB ATI AMD Radeon RX 5700
232GB Crucial SSD
465GB Crucial SSD
223GB KINGSTON SSD
931GB Seagate HDD
Can you see any power issues? Luckily I've got a mate looking to upgrade an even older setup so they will take the CPU/RAM/MOBO off me.
It's still a great choice, and as you can see the prices are very competitive. Can see you'll have any issues popping that into your current setup tbh. :)
Nope, agree with above, 650W psu will be more than enough, the 5700 max while gaming was 180W(166W av) and the 5600X is efficient, max gaming 134W..if you look at the bottom graph, they max'd 366W for the whole system while gaming(non overclocked) and that was with an RTX2080.
https://www.techpowerup.com/review/amd-ryzen-5-5600x/19.html
https://www.techpowerup.com/review/amd-radeon-rx-5700/31.html
At some point when directstorage for games is up and running, you can look at getting a nvme, as it'll only work on nvme gen3 or higher, or you can try flogging your ssd's and hhd to your mate as a pachage..A WD 1tb SN550 can be had for £70, or something like a gen4 Crucial 1Tb P5P for £112. the x570 can take 2 nvme's(both up to gen4), so one for OS and programs, 1 for storing games. But you can look at that at a later date...wait for sales etc and when you need it
