Hi lads im after some advice on the next card to get from my Ati 4870HD which ive owned now fo r a few years. What im after is advice on what range of cards would see a noticable jump in performance over the one above.
I dont really play the latest games, to last one i bought was BFBC2 last month which now pushes my card beyond its limit with all setting maxed out. I play at 1080P and i also have a second 24" monuitor hooked up. The biggest problem i have is my PSU which is one of those ticking time bomb Togan units rated at 480W so depending on your suggestions i may have to get a new PSU also (and a new case might aswell!).
Im abit of an ati fan so would like suggestions from this supplier unless something sticks out from the dark side.
Spend wise is as little as i can with a noticable boost in performance but max is £200.
In other words can i buy a £110 card and still see a massive boost in gaming or do i need to spend lots + PSU to see it.
Cheers fellas.
Cheers fellas.
