Hi,
Processor: Intel Core i5 750 2.66Ghz
Memory: Corsair XMS3 4GB (2x2GB) DDR3 PC3-10600C9 1333Mhz
Hard Drive: Samsung HD103SJ SpinPoint F3 1TB SATA
Video Card: Asus ATI Radeon HD 5770 "CuCore" 1024MB GDDR5
Operating System: Windows 7 Home Premium 64 bit
Motherboard: Gigabyte GA-P55A-UD3
Power Supply: Corsair TX650
I was thinking of getting an upgrade to my graphics card. I had originally decided on a GTX 580 but it's a heck of a lot of money. I was also thinking of getting a ATI 6950 and then in a bit when the price comes down and it starts to slow down a bit in games possibly get a second and crossfire them. Main reason for this is I only game at 1680*1050 so apart from crysis and metro 2033 the performance of the GTX 580 would be wasted on me for the most part although it would be fairly futureproof and the large memory would do me good if I decided to upgrade my monitor. This sound like a good idea? I know crossfire 6950s destroys gtx 580 on it's own.
Only problem is, does my mobo support crossfire? I have done some googling and as far as I can tell it definitely does not support SLI but it does support Crossfire?
If you look at this picture of the mobo you can see the 2 PCI lanes are x16 and x4 http://forum.giga-byte.co.uk/upload/files/P55A-UD3R picture.jpg Would this limit the performance of the cards a lot or is it miniscule? I am a bit confused if whether these 2 lanes means the cards will run at x8 x8 in crosssfire or x16 x4 or x4 x4.
Thanks,
Thanks,
Can someone else confirm this??
