Upgrade from 6850
24 May 2011
London
Hi
I have a friend,he is using an old i3 dual core,overclocked to4.2,with a 6850,he is wanting to upgrade his gpu ,what is the best card to go for ,that won't bottleneck his cpu,he plays a lot of wow and lol.?He also has 4gb ram,windows 7.
ive run a 7850 with an i3 540,even at stock cpu speeds it handled games fine at 1920x1080,im running 8gb of ram though so that would help things,plus you need a 64 bit operating system as 32bit can only use 3.5gb of memory
That's good to know,yes maybe upgrading ram is a good idea too,it's pretty cheap at the moment,if you change the ram do you have to redo the overclock,as it was an overclockers system?
you would need more qpi/vtt or memory controller voltage,im using 1.3-1.32v with 8gb at 1600mhz,it tends to be abit jerky/jittery with 4gb of ram,games like l.a.noire was,with 8gb its smooth
just take a pic of each bios setting/page before you add in the ram,then you wont lose your settings
