Hi,
Got the above on release a couple of years ago and getting that upgrade itch again
What would be worth upgrading too? Main criteria are that it fits in my case (think the above is 9.5" and there's not much more room than that) and runs a bit cooler/quieter. I currently have the sapphire 6870 which came with the stock AMD cooler/fan and it's pretty damn noisy once it spins up.
Would be paired up with a 2500k and running at 1650*1080 but I might upgrade the screen to a 1920 jobbie. Any thoughts? Budget not really an issue but I'm not sure I can justify those £300-400 cards as they mainly just produce lots more heat/noise I think and probably more than I need at those resolutions?
