Upgrade from 8800gtx
21 Jul 2007
Newcastle upon tyne
Hey all
Need some advice wanting to upgrade my other pc a little.
Have a big 8800gtx gfx card and want to upgrade it. What would you recommend not to expensive something for around £130
Already have q6600 @3.00ghz
Mobo is 680i sli
Thanks
If the cpu cooling allows, push the overclock further otherwise you will develop a bottleneck between the cpu speed and the gpu.
Something like a gtx460 / 6850 / 70 is a fair shout.
Thanks guys it's just to make it a little better adding more ram 1066mhz and a cheapest ssd into the mix to make it little faster also.
