Upgrade from a GTX 680 ?
18 Jun 2012
I have a Palit GTX680 2gb card and I'm looking to get a sizeable boost in frames.
What should i get ? a 780 ? 690 ? Titan ?
Or maybe another 680 and run them in SLI ? If so does it have to be the same exact same brand 680 or can it be any 680 ?
Me, I'd be looking at a 780, not only for faster framerates, but the larger memory.
If you do go down the slightly route (and if you game at 1080p, will still be a cracking setup) I believe you can use any 680.
I think I read some where (about Nvidia) that it has to be the same card and have the same amount of VRAM to work properly but I can't remember where I read it.. or if I just made it up lol I mean like MSI 680 2GB would not go with an MSI 680 4GB but a MSI 680 2GB will work with a GigaByte 680 2GB ... don't quote me on it though...
Any GTX 680 will work with any other GTX 680 as long as they have the same amount of VRAM.
