Upgrade from a X1800XT - Bang for buck?
20 Jun 2005
London..
Hi guys.
I feel like updating my graphics card with F1 2010 around the corner. Right now my system sits at:
E6300 C2D
Gigabyte DS4 965P
Hiper 580 Type R
2GB DDR2
ATi Connect 3D X1800XT 256MB
What graphics card will I be able to update to without having to change other parts? I think I don't really want to spend more than £100, don't mind second hand either.
Would it be also worth it to upgrade the CPU to a Q6600 or something?
I'm really out the look with these things, so if anyone could offer me advice I would be grateful.
Thanks
overclock the 6300 to 3ghz, if u can stretch to the GTX460 I think it would be worth it.
If you cant overclock or dont want to spend the extra then go for that 5770 for £80.
It will run 2010 fine
