Is there a possible upgrade from a S2417DG, it's 24inch 1440p and 144hz OC165hz its a TN Panel but once adjusted I think the images look very sharp and colours are good.
I actually like this monitor and would keep it but it only has GSYNC and I was hoping that my next GPU would be AMD so a monitor that is Freesync compatible.
This monitor has issues (more than one post like this) running with an AMD GPU over DP so you have to run over HDMI at 60hz.
I'm used to sharp images and small text windows 100% scaling on 1440p at 24inch.
Does anyone know which monitor would be an upgrade path if any?
Note: I play League of Legends, New World and would probably try CoD once upgrading my 970GTX. So not sure if a larger monitor would make gameplay worse looking around the screen etc.
