- 9 Dec 2008
Hi,
I'm not so familiar these days with the detailed comparative specs of Intel cpu's from over the past few years. I have a comp with a E6550 Core 2 Duo 2.33Ghz. I was considering getting a used Q6600 Core 2 Quad 2.4Ghz. That would also have twice the L2 cache at 8MB. That particular model happens to also be nicely compatible with the mobo and installed BIOS version.
That looks to me like a significant upgrade for this comp. By doubling the number of cores and L2 cache, it should be more than twice as fast.
BUT I know Intel has had CPU releases before where the CPU doesn't perform near at what it looks like it should and then they improve on it with a later model. So I'm just wondering if this upgrade would actually be as it looks to be in terms of performance upgrade:
E6550 Core 2 Duo 2.33Ghz, L2 4MB
to
Q6600 Core 2 Quad 2.4Ghz, L2 8MB
Thanks
to
Thanks
. Its really easy, just raise the FSB to 333 and leave the multi at 9, so 333 x 9 = 3.0GHz. Most G0's will do this on stock voltage, or if not, just raise the vcore a couple of levels. That's really it. Then just stress test it with intel burn test for 20 passes on high settings
