Upgrade from GeForce 8300 GS
1 Nov 2011
I have a Dell Vostro with a GeForce 8300 GS, and i want to upgrade.
Looking at a Asus ATI Radeon HD 6450 low profile 1gb card......would this fit ok in the Vostro 200 tower?
Also, the PSU is 300W....am i going to need to upgrade this as well?
Yes it will work but the gpu will be underpowered and would put great strain on your psu, probably causing the psu to fail. If the psu goes bang then it may take out other components with it so i would sugest an upgrade.
