Upgrade from GTX 970 to GTX 1660 Super?
7 Mar 2005
LU7
I am currently running the system below and am wondering if replacing the GTX 970 with a GTX 1660 Super would be a sensible upgrade to prolong the useful life of the PC? I have a 34" Dell curved monitor, U3415W @ 3440x1440.
i7 4790K @ stock
Gigabyte Z97X-UD3H-BK
16GB DDR3
GTX 970
EVGA 850W PSU
The single fan on the 1660 Super is causing me to question whether I should get a 1660 or 1660 Ti. Does the single fan work OK for cooling the card whilst not being too loud?
i7 4790K @ stock
16GB DDR3
GTX 970
EVGA 850W PSU
what FPS are you getting in games with a 970 at 3440x 1440p ? :eek:
It was about 45 but then I realised the resolution wasn't 3440x1440 but 2560x1080. If I up it to 3440x1440 and put the settings up high, the VRAM meter goes over the 3.95GB to about 4.13GB I think it was and the FPS drops to about 35 on average but did drop to 21 when I was moving around. The graphics still didn't look brilliant, for example, the road markins went very lo-res a few meters in front of the car.
The 5700 XT looks good. I notice it needs a 6 pin and an 8 pin power connector. My 970 uses 2 x 6 pins so I'll have to check my PSU to see if I have a spare 8 pin connector available. Is the equivalent nVidia card for the 5700 XT's price not worth it over the AMD card?
If you can up your budget you could get a 2070 super that offers 1080ti performance or you could pick up a used 1080ti for £350 if you are lucky.
I run a 1080ti at 3440x 1440 and it’s sweet as a nut
Budget probably £300-350. Haven't got a problem going AMD. Is th RX 5700 worth the extra money?
A resounding YES. At 350$, tho, you might snag a 5700XT. Check out the sale in ocuk. I upgraded from GTX 1060 to the 5700. Twice as fast and about same power consumption when i undervolt.
That PSU has all the cables needed for sure. I have an evga 850W B2 and it handled a couple of R9 290s.
970s only really have 3.5gb of VRAM. The final .5gb is much slower and if you’re using it performance will suffer.
