Upgrade from GTX 970
12 Jul 2005
ive got a 2700k cpu and 16gb DDR3 so want to avoid a bottle neck at 1080p. Also want something that will last me another year or two before a full rig update as my system is still plenty powerful enough to run most things on high - want a bit more future proofing though as the 3.5gig vram is struggling at times
What’s best? 1070ti?
I moved from a GTX 970 to a GTX 1070 paired with my 2600k @4.8GHz and it'll play Battlefield V at anything between 90-100fps.
If you can get one cheap enough get one of those, failing that spend a bit more and get a 70TI or 1080 but they're overkill for 1080p
I've gone for one of the Vega 56's to replace my 970 - although I'm also investing in a freesync monitor which was another reason for going AMD as opposed to Nvidia!
Same here, I bought a freesync monitor and replaced my 970s with a Vega 64. I'm done with nvidia.
Hey guys - just resurecting this thread - will make the upgrade from my 970 when I get paid at the end of this month.
So, 1080p, i7 2700k, 16GB ram and 144HZ Samsung monitor.
Still vega 56 thats best?
yes v56 sapphire pulse at £300 with 3 games
hit the auto undervolt option in Radeon settings and it's good to go, 1070 ti perf or 64/1080+ if you oc
