Hi all,
I have the itch to upgrade and would like some advice on my shopping list, which admittedly I've mostly gathered from asking Bard/Gemini.
Apart from general computing when working from home (DB admin, PHP coding, network admin, internet research), I do play a few games (at 2K) such as Baldur's Gate 3, Diablo 2 and Heroes of the Storm. I'm not really into overclocking, mainly because I just don't have time to mess about. I'm certainly not a power user - oh and don't require onboard Wi-Fi.
Ideally I want to avoid breaking, say, the £400 mark (I have a family and mortgage to consider), but I might be persuaded to go a bit over if the deal was too good to miss and it made sense for future-proofing.
Current rig:
I'm pretty certain the mobo/CPU combo is where I sorely need to work on, so I was looking at plunging for (staying with DDR4):
Would be really grateful for any feedback.
Thank you!
Current rig:
- Asus Z170 Pro Gaming Motherboard
- Intel Core i5-6600K LGA1151 3.5GHz CPU
- 2 x 8GB Corsair "Vengeance" DDR4 2400MHz CL14 RAM
- 2 x 4GB ? DDR4 (some crap I picked up from work)
- Cooler Master RR-212X-17PK-R1 Hyper 212X CPU Air Cooler
- Gigabyte Geforce RTX 3060 Windforce OC 12GB
- Cooler Master B-series V2 700w Power Supply Unit 80+ Efficiency
- ARCTIC Freezer 34 eSports DUO - Tower CPU Cooler with BioniX P-Series case fan in push-pull, 120 mm PWM fan, for Intel and AMD, LGA1700 compatible - Grey/white (~£48)
I wanted a white fan! - ASUS ROG Strix B550-F Gaming Motherboard Socket (PC) AMD AM4 (~£145)
- AMD Ryzen 7 5700X Desktop Processor (8-core/16-thread, 36 MB cache, up to 4.6 GHz max boost) (~£160)
Thank you!
