Upgrade from i7 3960x to Xeon 2699v4
2 Oct 2009
Hi.
I am looking to buy a mobo,ram and cooler for my Xeon 2699v4.
I wanted to know what motherboard ram cooler combo you would go for?
I am looking at the gigabyte x99 P5 which is reduced at the moment.
I rarely game. It's a work station.
VMs.
Plex 4k transcoding.
Just want some ideas what other techs would get?
Thanks.
Cal.
Difficult one, personally if i owned that cpu a reduced price on the board wouldn't influence my choice, i would be looking at the board with the best power and Vrm's, its a beast of a cpu and you dont want to be power throttling as it would negate any advantage of such a high threaded cpu
Difficult one, personally if i owned that cpu a reduced price on the board wouldn't influence my choice, i would be looking at the board with the best power and Vrm's, its a beast of a cpu and you dont want to be power throttling as it would negate any advantage of sur a high threaded cpu
I have emailed Gigabyte asking that very question about power throttling.
I think xeon 2XXX have to be used in dual socket boards.
there's a 1680 v2 which is 8 cores and overclockable which you could use with your existing board.
I'd go with something Intel C612 based, probably a SuperMicro board. For RAM lots of ECC and for cooling maybe a Swiftech 240-X.
