upgrade from i7 920 to i7 4960k
10 Apr 2015
Hungerford, UK, Earth
my main gaming pc is as per sig, cpu is currently 90-98% on BF1.
I have a second PC with a z97 board 16gb RAM and a m.2 SSD, i5 4460, is it a worth while upgrade to basically swap the guts over between the 2 pcs and get an i7 4960k, if I get £100 for the i5 then the overall outlay is not much at all
xeon doesn't work overclocked tried that, and a lot of googling my board and revision wont overclock xeon
The 4960K is S2011 though and those boards are not cheap, so I don't think it would be exactly an economical upgrade.
Be easier sell that 4460 and buy a 4790 or 4770 - unless you have the i7 model wrong in your OP?
I posted wrong model oopsy upgrade to i7-4790K , and I have the z97 mobo and ram
went for the i7, temps where a little high, so i took the aio off again and fitted with the case flat on the desk and all sorted now.
sorry for little offtop but did i miss something ? i get 18 months ago 4790k for 240 from ocuk now is for 349? is it brexit or what :D?
Dam boy what mother board was your 1366, i dropped in a x5670 in my ga-ex58 ud3r few month agos internet said it wouldnt overclock got it running 4ghz never seen over 65% cpu usage in bf1
did you try dropping the qpi clock ratio to 36 and the uncore to 12 mine wouldnt overclock without that, its a bit sensitive about ram speed too
well it dosnt really matter, since I sold it lol... my i7 920 is now retired to my second pc, and I have dropped the overclock to 3ghz
Tried BF1 with my other PC (X5675 @ 4.2GHz) and it cannot max GPU usage in few spots with a 970. Runs way better than stock CPU speed though.
