Upgrade from my antec 900?
13 Sep 2007
Gloucestershire
I have a antec 900 and its all a bit cramped and im ordering water cooling kit and think I need a lot more space and better cable managment. Anyone got any ideas? Needs to be supper huge, I dont need a PSU and I dont need case fans. MUST BE REALLY SILEMT. Hence the move to water cooling
Found a A-PLUS Acase X-BLADE PC & Server Case ATX BTX 11 Bays for £100 which seems huge but cheap build quality I guess. Any opions on this?
Cheers
Sheldon
lain li v2000? the fans are easy enough to remove and so are the hdd bays allowing you to fit your watercooling kit ,can't tell if it is silent though due to the 120mm delta in mine.
its also seems big enough for the stuff in your sig
Lian Li PC-G70, Coolermaster STC-T01, or if you have a lot of cash spare the Silverstone TJ07
All are well built cases with tons of internal space
