Upgrade from Oneplus 9 pro?
26 Nov 2010
Thorne Yorkshire
Hi folks, I'm after your opinions on an upgrade from my current Oneplus 9 pro phone.
Only reason I'm looking to upgrade is that the security updates for it have now reached end of life. Other than that I'm perfectly happy with it.
Mainly use it for emails, browsing, bank transfer and streaming video. Not used for gaming.
My budget is up to £200. Prefer new but I'd be comfortable with an "A" grade refurb.
Wireless charging is a feature I really like but it seems that wireless charging is not widely available on phones in my preferred budget.
Been looking at the Motorola G75 which was released in October 2024 but reviews comparing it with my Oneplus 9 pro suggest it's a slight downgrade.
Any suggestions please?
The 9 Pro is a high end phone, so a lot of phones in the £200 budget will struggle to compete against that. If you want a phone with long guaranteed security updates, I would try save up more for a Google or Samsung phone instead. Pixel 9a for example if you can reach that, also comes with wireless charging.
The Poco series are good phones I'm still using a Poco x3 NFC but installed crdroid on it a few years ago. it's now on (android 16) and still working like a brand new phone.
Update: I eventually got myself a CMF 2 pro. Seems fine to me. Can't fault it. It'll do for me. I like the slightly bigger screen from the 9 Pro.
The CMF doesn't have wireless charging though. I suppose I can get one of those wireless charging adapter thingies? Are they any good?
