Hi all. I've had the original iPad since launch day (told myself they were stupid pointless devices, played with a friends one and ran straight out to buy one....) but it's getting a bit long in the tooth now. Browsing (it's main purpose) is slow and browsers (chrome and safari) fall over regularly. Battery isn't what it used to be either, so it's time for an upgrade.
I'm torn though - the obvious choice would be the current 4th gen iPad (16gb wifi is fine) but the iPad mini is tempting too.
The mini is more comfortable to hold and a lot cheaper to buy - but the screen isn't great and it's effectively iPad 2 hardware... Seems to be quite a bit slower than the 4th gen.
The 4th gen has the epic screen and much better spec, but the upgrade cost would be nearly double the amount. Is it worth it?
cheers!
