Upgrade from Radeon HD 4890
Man of Honour
1 Nov 2006
Hi all,
Which card(s) should I be looking at to replace my old 4890 please? (Budget up to £150).
I have an old system built around 2008-9. Spec as follows (minus the 8800 gtx).
Thanks. :)
R9 380s are about that new and worth consideration. You saving to upgrade the rest later?
Cheers all. Yeah I realise other components are also well out of date now and could do with an upgrade but I'm still generally satisfied with the performance but I'd just like to be able to play Directx 11 games e.g. Dirt Rally. :)
I think Abit is not around anymore and you wouldn't have up-to-date motherboard bios that is may be/likely required for using with modern cards.
So yea as other people mention, you should probably look into upgrading your platform first.
i mean i know its old but is a q6600 rly so bad?
My old Q6600 overclocked to 3.60GHz would somewhat bottleneck even my 5850...but that's isn't the main concern here...my worry for OP would be that Abit motherboard may not be compatable with dx11 gens cards (no display), and there won't be update bios available since the company has folded for years.
My old Q6600 overclocked to 3.60GHz would somewhat bottleneck even my 5850...but that's isn't the main concern here...my worry for OP would be that Abit motherboard may not be compatable with dx11 gens cards (no display), then the company has folded for years.
This^^^, modern UEFI GPU's on ancient boards, it can be problematic.
He's also running 4GB of DDR2, if he wants to run DX11 games like Dirt Rally he will need 8GB of RAM.
He will find it very difficult if not impossible to find 8GB of DDR2, he will probably need to try and find a DDR3 Board for that CPU so he can run 8GB of DDR3, again, good luck with that....
Even if he manages that its running at 2.4Ghz, it will bottleneck the crap out of a 380 so he will have to get some after market cooling to overclock the crap out of that CPU and it will still bottleneck the 380 into oblivion.
By the time he's done getting his system DX11 ready it will have cost him nearly as much in ancient used parts, what he will get for that is a machine that is DX11 ready but only just.
Bite the bullet, beg, borrow, save..... upgrade the core of the system.
+1
Not much looking at the specs :D
:) Not too far wrong there but it served me well at the time and indeed for a number of years after. It still does practically everything I want it to do (except play DX11 games!). ;)
Thanks for all your replies. I'll have to weigh up if I think it's worth reinvesting in a rebuild. Doubtful tbh but we'll see. :)
What resolution are you running? Something secondhand from the 5000 or 6000 range would get you running DX11 games on the cheap but it doesn't sound like it will be worth spending much on a gpu for that build.
I know an HD5850 or HD6870 should be fine with that setup. What about something like the R9 370 which is based on the old HD7850??
Do you think it'd be worth picking up a second hand 5850 or 6870 for say £50 on ebay or am I just gonna be wasting my time/ money?!
