- 10 Aug 2015
Currently looking to upgrade a friends PC with a RX590 GPU
If you had a budget of £500 what would you go with ? I was thinking 3060ti but they currently have a 1080P monitor, would you recommend 2K gaming with the 3060ti or keep the 1080P and have the Ray tracing and extra FPS ?
Would they see any difference in the RX590 vs RTX3060ti or worse case a RTX3050 ?
Thanks
Thanks
